PDF
08-09-2010 2:06 PM
Hi
Does anybody know how to get Acrobat Distiller to monitor a folder and automatically convert any word documents to PDF
Tried all sorts but no joy as yet!
5 REPLIES 5
Re: PDF
08-09-2010 3:44 PM
I have Distiller 6.0 so I don't know if it is the same as your version.
When you open Distiller, there is a Settings tab where you set "Watched folders" and set process interval (how often folders ate checked?)
...never used it so best of luck!
Re: PDF
08-09-2010 3:49 PM
yeah the option is there but it constantly fails to convert doc files.
I found a free alternative actually so all is good, thanks
Re: PDF
08-09-2010 5:53 PM
Just for info, what did you find?
I use CutePDF for creating PDF files but it cannot create on the fly from folders like Distiller.
Re: PDF
08-09-2010 6:23 PM
Quote yeah the option is there but it constantly fails to convert doc files
We use distiller in the office, but you need to print the word document to a postscript file in the watched directory. Then it will convert it to pdf automatically.
Re: PDF
08-09-2010 8:34 PM
Quote from: Nick Just for info, what did you find?
http://www.pdf995.com/
Works a treat
