PDF to Word
morgan2476
PDF to Word
Hi I am copying text from a double column pdf file.  I am copying one column at a time.  The problem is when I paste on to word the formating remains the same, ie, the text is to one side of the document.  How do I format word layout to enable the text to use the full width of the page?
Fixes: 10
Re: PDF to Word
I'd suggest getting rid of the formatting altogether (fonts and everything). One way to do that would be to first paste the text in to a text editor that doesn't support formatting (e.g. Notepad) and then copy paste from there in to Word.
On Word 2010 there is a Paste Special which includes an Unformatted text option - that will do the same thing. I don't know if that is available on earlier versions.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 62
Re: PDF to Word
Quote from: jelv
It is and in Open Office Writer as well
MrT
Re: PDF to Word
You could create a 2 column / 1 row table in Word and then copy each column of your PDF to the table using the Unformatted text option.
wisty
Fixes: 6
Re: PDF to Word
You could get a copy of PDFtotext ( its open source) which will save the copy & paste effort if its a long document.
kmilburn
Re: PDF to Word
Libre Office (and probably Open Office) can also load PDF documents directly.
