PDF to Word
- Re: PDF to Word
PDF to Word
24-12-2011 9:36 AM
Hi I am copying text from a double column pdf file. I am copying one column at a time. The problem is when I paste on to word the formating remains the same, ie, the text is to one side of the document. How do I format word layout to enable the text to use the full width of the page?
5 REPLIES 5
Re: PDF to Word
24-12-2011 9:54 AM
I'd suggest getting rid of the formatting altogether (fonts and everything). One way to do that would be to first paste the text in to a text editor that doesn't support formatting (e.g. Notepad) and then copy paste from there in to Word.
On Word 2010 there is a Paste Special which includes an Unformatted text option - that will do the same thing. I don't know if that is available on earlier versions.
Re: PDF to Word
24-12-2011 10:18 AM
It is and in Open Office Writer as well
Quote from: jelv On Word 2010 there is a Paste Special which includes an Unformatted text option - that will do the same thing. I don't know if that is available on earlier versions.
Re: PDF to Word
24-12-2011 10:41 AM
You could create a 2 column / 1 row table in Word and then copy each column of your PDF to the table using the Unformatted text option.
Re: PDF to Word
24-12-2011 11:34 AM
You could get a copy of PDFtotext ( its open source) which will save the copy & paste effort if its a long document.
Re: PDF to Word
28-12-2011 2:35 PM
Libre Office (and probably Open Office) can also load PDF documents directly.
