PDF Viewer wanted
- PDF Viewer wanted
PDF Viewer wanted
18-03-2015 2:03 PM
Must be able to open PDF`s attached to emails.... ( window Mail )..
Any offers ?
Re: PDF Viewer wanted
18-03-2015 2:05 PM
18-03-2015 2:09 PM
I use Nitro PDF Reader...
18-03-2015 2:09 PM
18-03-2015 2:32 PM
18-03-2015 6:07 PM
Quote from: w23 Any particular reason you don't like / don't want to use Adobe Reader?
Not my machine.... but the machine it is needed on... Advent Laptop... has Norton on it,... and when I tried to download Adobe Reader... it chucked it back, saying it was risky...
18-03-2015 6:26 PM
York.
18-03-2015 6:32 PM
thanks for suggestions...
as always...... much appreciated.....
18-03-2015 8:07 PM
18-03-2015 8:34 PM
Personally, I have no faith in the likes of Norton, Kaspersky etc.... Always had freeby antivirus, and only had a couple of trojans, which they picked up and dealt with... if it were my machine, I would dump Norton and download from Adobe... but.. not for me to change someone elses paid for anti virus... ( unless they ask me to do so.... )...
18-03-2015 8:42 PM
I ditched foxit for 2 reasons, it couldnt write to PDF files and some PDF files didnt work on it, I cannot remember why I ditched the other.
Adobe reader now days seems much better than it used to be. So I stick to that now, but I do disable the crappy plugins it adds to browsers so PDF files always open in the app not the browser.
18-03-2015 9:07 PM
I've used Adobe & Norton Internet Security for more years than I care to remember and never had any problems.
My current PC has only been in action for a few weeks. N.I.S was installed straight after Windows and Adobe installed a few days later. N.I.S. didn't throw a wobbly!
York.
18-03-2015 11:57 PM
Quote from: Oldjim I use pdf-Xchange Viewer and it just works plus allowing a reasonable bit of annotating files
+1
I also use PDFFill tools. It allows you to join and split PDFs as well as much more
Forum Moderator and Customer
19-03-2015 5:19 AM
19-03-2015 11:19 AM
My goodness - a 90 year license! Where do I get one of those?
York.
