PDF Files
Fixes: 238
PDF Files
I have some forms as PDF files that have many fields to be completed but they are not editable.
Is there anyway I can make these editable or is there another (preferably free) program that will allow me to do this?
Cheers.
Forum Moderator and Customer
Fixes: 62
Re: PDF Files
Fixes: 238
Re: PDF Files
That was quick, oldjim. Thanks. Downloading now.
A Google search threw up CutePDF and PDFill even though I entered free in the search!
I can't see the point of paying for some software that I'll only use, say, once every couple of years so your link may just be the solution I'm looking for.
