PDF Files
- Re: PDF Files
PDF Files
26-09-2010 3:33 PM
I have some forms as PDF files that have many fields to be completed but they are not editable.
Is there anyway I can make these editable or is there another (preferably free) program that will allow me to do this?
Cheers.
Cheers.
Forum Moderator and Customer
2 REPLIES 2
Re: PDF Files
26-09-2010 3:40 PM
http://www.tracker-software.com/product/downloads
PDF-XChange Viewer
PDF-XChange Viewer
Re: PDF Files
26-09-2010 3:48 PM
That was quick, oldjim. Thanks. Downloading now.
A Google search threw up CutePDF and PDFill even though I entered free in the search!
I can't see the point of paying for some software that I'll only use, say, once every couple of years so your link may just be the solution I'm looking for.
