PC is dead
- PC is dead
- « Previous
- 1
- 2
- Next »
Re: PC is dead
10-06-2008 5:02 PM
It used to be under someones avatar as a stupid statement, Ithink it was one of the posh brigade, Bright spark, moderator etc., a failure or the Keyboard interface produce a Bios message, press any key to continue, OK, but which key, you havnt a working keyboard
Typical.
Try a different keyboard, it wont work without one, could be the battery flat on the keyboard, it must have some form of power.
Typical.
Re: PC is dead
11-06-2008 8:36 AM
Dodgy memory! One memoy stick removed and all ok.
Re: PC is dead
11-06-2008 11:36 AM
problem solved. sweet.
- « Previous
- 1
- 2
- Next »
