PC freezing
- Re: PC freezing
- « Previous
- Next »
Re: PC freezing
04-07-2021 7:11 PM
@penfold wrote: Anyone any other ideas????
Just a thought, what are the temperatures of the graphic card? If it runs ok but then gets into problems while actually gaming, I'd be more inclined to look at the fans (make sure they do kick in when required) and the memory. Have you got a spare graphic card to try?Maybe take out the card to see if you can see any obvious problems on it.
While I too have had some graphic issues recently (RX5700) I have finally nailed it. I thought it was a windows / driver issue, memory issue or even the monitor but it turned out to be the HDMI cable. Every so often it would fall over. Since I've bought a new one, no problems whatsoever.
Re: PC freezing
04-07-2021 7:17 PM - edited 04-07-2021 7:29 PM
Thanks. Cards recently been out, during the rebuild into a new case.
I did note when looking in the AMD software, that the fan speed settings were rubbish on automatic, so set them to manual, and created a new fan profile. Oddly enough if the system freezes, it resets the fans to automatic again!! GPU temps with my fan speed profiles top out around 55 degrees. Its also the whole system, as the keyboard etc are unresponsive.
I have spare HDMI cables so will try one.
Oddly I had him play a different game tonight, one he installed onto his PC, Halo. Its an old game but he put the video setting to max, at 1080p resolution, and not 1 issue....... He can also watch you tube videos at HD resolutions in full screen with no issues...
Re: PC freezing
04-07-2021 7:49 PM
If the AMD software detects an issue, I've noticed that things tend to get reset to default settings. I tend to overclock my GPU card (which is only what it is supposedly rated at anyway) but come a problem at boot and I can guarantee its gone back to the default settings.
The only other thing that springs to mind (and bearing in mind it is online gaming) are you losing the connection - maybe even temporarily but enough to get the game(s) to throw a wobbly. I've had it in the not too distant pass on World of Warships where things lock up, screen, mouse etc but wait long enough and things catch up again. Not good for gaming admittedly. btw That problem turned out to be a game file issue.
Just thoughts anyway. Good luck.
Re: PC freezing
11-07-2021 8:35 PM
Re: PC freezing
11-07-2021 11:45 PM
Bios battery ?
Re: PC freezing
12-07-2021 12:07 PM
Thanks Shutter....
At this point in time I will try anything. Ill replace the BIOS battery tonight.
- « Previous
- Next »
