PC fail to boot.
- Re: PC fail to boot.
PC fail to boot.
24-04-2009 7:41 PM
Pc had been work normal then I noticed HD activity LED was permanently on and screen saver was on and frozen. I had to force the PC off by holding the on/off switch. When I swiched it on again it would not boot.
Got to the screen where it says 'PCI device listing...' 13 item are on the list, the last one being ACPI Controller.....then just a flashing curser.
I realise this could be a million different things wrong but where do I start?? Any help would be much appreciated.
I am running XP Pro,(or should be)
24-04-2009 10:09 PM
Can you get to a command prompt and check your hard disk?
Regards,
Neil
25-04-2009 10:18 AM
Paulo
26-04-2009 1:57 PM
26-04-2009 4:11 PM
http://www.michaelstevenstech.com/XPrepairinstall.htm
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
Regards,
Neil
27-04-2009 12:08 AM
"..cannot find a previous version of Windows on this PC....setup needs to verify that you qualify to use this product. Insert Windows CD"
The CD is already in place as this was the only way I could boot and get this far. I then press Enter and I get the message saying
"..could not read CD or the CD is not a valid Windows CD"
The CD must be readable otherwise I would not have been able to get this far and I know it is a valid CD as the original OS came from this CD and I have the key for it.
Any ideas what is going on?
Regards Paulo
27-04-2009 11:01 AM
27-04-2009 11:07 AM
27-04-2009 5:48 PM
http://www.webtree.ca/windowsxp/repair_xp.htm
scroll down until you see the grey screenshot followed by th usual bluescreenshots.....
further down it gives instructions how to copy files from the XP cd if the boot sector is corrupt....
here is another version that may be helpful.....
28-04-2009 11:12 AM
I can get to the Recovery Console ok but I dont get the page where it asks to choose "installation that you want to repair". All I get is the prompt C:\> Does this mean there are no longer any Windows OS (files) on my HD?
28-04-2009 11:16 AM
You need to choose to install not repair first.
Install then loads lots of files and then looks for existing installations later on and offers the repair option then.
Read the screens very carefully as some of the keystrokes are quite specific and odd!
If you do actually want to use the command-line repair console then choose repair at the first opportunity.
Either way, if your system needs drivers to access the disk (e.g. RAID controller) you need to have them handy on a floppy and hit F6 when that prompt appears at the bottom of the screen, or it won't find the hard disk.
28-04-2009 11:43 AM
Cannot try F6 (RAID) etc because this PC does not have a floppy drive and I dont have the floppies.
Where now guys I'm at a loss!
28-04-2009 4:24 PM
Not a terribly expensive exercise, a new 160GB drive is less than 30 quid from PC World.
You have checked all connections to your existing drive?
Regards,
Neil
28-04-2009 4:31 PM
28-04-2009 11:26 PM
Check your bios and make sure it can see the hd change it from auto and detect it so you know its right
Some things to try get to the recovery consul and try these command
chkdsk c: /f
fixmbr
fixboot c:
reboot after these 2 if it still doesnt work try
bootcfg /rebuild
Your problem if they dont work is I would guess you pc is up to date and have SP3 on it your windows cd which you are trying to repair it with will be either no SP or SP1 so if you try any repair it will muck it up as it will replace files with old ones. To do a repair you need to slipstream the SP which is on your pc probably 3 instruction on how to do it are here
http://www.helpwithwindows.com/WindowsXP/Slipstreaming_Windows_XP_Service_Pack_3.html you need a working pc to do this which may be a problem
If you get a c> prompt you can see your files by typing dir c:\ *.* /s
