PC does not recognise VGA connected monitor
- Re: PC does not recognise VGA connected monitor
01-10-2014 12:09 PM
I have just had to reinstall Windows 7. During the installation I had two monitores connected , one via an HDM1 via a card installed a couple of months ago and one VGA on the as built card with the Desktop.
Both worked perfect previously.
Now the VGA cabled screen is not recognisted. When I unplug it, I get a No Signal message. Plug it in again, and the screen goes to standby. When I go to select the dual screens on Control Panel, did not show t he VGA cabled screen.
Any ideas?
01-10-2014 1:52 PM
in windows , right click on screen resolution , it should show your monitor , click on detect , see what you get
01-10-2014 1:57 PM
You are correct. Two graphics card. The monitor I am trying to detect is in the original build of the desktop.
When I click Desktop nothing changes.
01-10-2014 2:04 PM
if you've tried this go to control panel >devices>device manager> expand display adaptor and make sure both are listed and both are showing as enabled under device properties
baring a change to the bios configuration I'm not sure why one would not work unless your on-board VGA adaptor just died, is there a secondary output on the GFX card that you could use instead for the additional monitor either a VGA or a DVI output will often work with the adaptor in the GFX card box, depending on the card you installed
01-10-2014 2:44 PM
01-10-2014 2:52 PM
01-10-2014 3:58 PM
this is from MS help http://support2.microsoft.com/kb/976064
02-10-2014 11:55 AM
02-10-2014 9:26 PM
Quote from: nanotm have you tried unplugging the HDMI monitor and rebooting to see if it recognises the VGA one ?
Thanks for the reply. I can get the VGA monitor to operate if I unplug the HDMI cable. Having completed start up, I plug back in it will not recognise the television connected via HDMI. If I leave the HMDI plugged in and power down and start up agsin, it will be only the HDMI television that will start up.
Before the reinstall of Windows 7, I used to be able to run both as a Primary and Secordary screen.
If it helps on the card added to the desk top as well as the HDMI there is a (I believe it is called) a VDI connector.
02-10-2014 9:44 PM
Quote from: rongtw yup most GFX cards will have more than one output for multi monitor setups mine has 1DVI 2HDMI , normally you would run 2 monitors off one card not 2 cards ' as you say the bios normally disables the onboard one .
Tried Windows Key and P and it does nothing. Guess that is because the desktop thinks there is only one monitor connected
02-10-2014 9:49 PM
03-10-2014 7:38 AM
03-10-2014 4:03 PM
If you open the Device Manager, what appears in the 'Display Adapters' section. That would give a hint to the card being present and their state of usability.
03-10-2014 4:08 PM
