PC crashed, Error code 00000019
andymiff
Hi there, last night I was on the pc and the screen sudennly went black...
I tried finding out why, when I re booted, on the net, and found how to find the error thingy (see? im extremely technically mided hehe, its a error thingy lol ) and the error said..
Error code 00000019, parameter1 00000020, parameter2 fbcd09d0, parameter3 fbcd1230, parameter4 ed0ced09.
I'll add a screen print i made of it here so you can see all it said
hope someone can help me know why... this happenned?
jnwright
Re: PC crashed, Error code 00000019
According to M$ here, it is a problem with the NTFS file system on Windows Server 2003. It was corrected initially using a hotfix and was then fixed in Service Pack 1. Since you haven't mentioned Windows Server 2003, I may have made a wrong assumption!
StickyMick
You had a look in "Event Viewer" for some clues? It's under "Administrative tools" in "Control Panel".
andymiff
yes its the event view thingy i found it in... but well, what it says doesnt mean anything to me Sad I think @ the time it happenned I was just surfing... I did see something somwhere else saying that this is a blue screen? (even tho it was black lo l) and that it could be to do with SP3? well windows updated me to SP3 bout a few days/week back
Try doing a chkdsk /r at a command prompt, to check any file system errors, also may check the memory using memtest, run it a few times, as memory faults do not always show up on the first pass.
andymiff
sorry, but what is or how do i do a "chkdsk /r at a command prompt"? (yes i know, im thick lol ) and what is memtest? I do know I need an upgrade in my ram...
Start - run - and type cmd.  This opens a command prompt. At this type chkdsk /r to run a disk checker that will also repair any problems it finds
Memtest is a program to test your memory for errors.  You can download it here http://www.memtest86.com/
