PC Cleanup
- PC Cleanup
PC Cleanup
24-02-2009 3:39 PM
I'm desperately trying to find the Anti Virus program that is supposed to be installed on my PC.
I want to install AVG but I keep getting a message during installation that I already have an AV installed and I should uninstall this first.
I have tried to find it and nothing sinister shows up in Add/Remove.
Is there anything out there that would help to detect regue software etc.
Following on from this I'd really like to try and clean up my PC and clear out all the rubbish.
Any advice?
Any advice?
7 REPLIES 7
Re: PC Cleanup
24-02-2009 3:47 PM
Re: PC Cleanup
24-02-2009 3:59 PM
Do you have any idea as to what Anti virus programs have been installed in the past
Re: PC Cleanup
24-02-2009 5:29 PM
oldjim - i did have norton 360 on here once but i uninstalled it using nortons own facility and then installed avg.
It was running perfectly but then all of a sudden started to play up so i tried uninstalling it etc with no luck.
and to answer mal0z, I can't even get onto that website even though my connection is working etc.
Re: PC Cleanup
24-02-2009 5:41 PM
If you can't get there something may have messed up your hosts file - can you check that
If you can't get there even after that please advise which version you want and I will put it on my webspace and send you a link by PM
Re: PC Cleanup
25-02-2009 10:06 PM
Quote from: Oldjim If you can't get there something may have messed up your hosts file - can you check that
I definitely can't get on the web site with this particular PC but I can on my others so very stange.
I'd like to uninstall it completely and then reinstall ver 7.5.
Thanks OJ
Re: PC Cleanup
25-02-2009 10:23 PM
PM sent
Re: PC Cleanup
26-02-2009 12:47 PM
Thanks Jim.
I appreciate your help.
