PC Build
- PC Build
- « Previous
- Next »
Re: PC Build
22-04-2017 11:38 AM
Re: PC Build
22-04-2017 11:44 AM
@Anonymous
What drive did you select, was it a network drive and not a local ?
Re: PC Build
22-04-2017 12:00 PM - edited 22-04-2017 12:15 PM
Drive C.
@30FTTC06 - Crystal Mark test results.
I don't know if I should be pleased or disappointed to be honest.
Re: PC Build
22-04-2017 1:20 PM
What is that a 3200/800 NVMe 120GB or sata ?
Re: PC Build
22-04-2017 1:31 PM
My hard disk can beat those 4K random readings...
Re: PC Build
22-04-2017 1:36 PM
It's a 1.12TB Fusion Drive with a 119GB partition for the Windows VM.
Re: PC Build
22-04-2017 1:37 PM - edited 22-04-2017 1:37 PM
@VileReynard - You knew this was coming, prove it.
Re: PC Build
22-04-2017 3:23 PM
My disk has 4K sectors, so
Re: PC Build
22-04-2017 3:32 PM - edited 22-04-2017 3:33 PM
Go for the i7 7700K even if u dont overclock it, you still run good speeds of 4.2ghz with 4.5ghz boost, if youdo you will need good cooling
Re: PC Build
22-04-2017 4:04 PM
That lad cracks me up
Re: PC Build
22-04-2017 4:23 PM
well i may join in , Just a basic Samsung 850 EVO
Re: PC Build
25-04-2017 7:26 PM
@30FTTC06 wrote:
I am curious to see if that Strix 6GB 1060 will work ok in a P8Z68-V
Erm, no it doesn't.... hey-ho and all that.
Re: PC Build
25-04-2017 11:48 PM
I don't trust these benchmarks.
I've got 2 x 1TB hard disks & 8GB, so I installed Windows 7 as a VM (using VirtualBox - so not very efficient).
I ran this CrystalDiskMark thing and got:-
Which seems quite respectable, all things considered.
Everything's probably in memory or disk caches anyway.
- « Previous
- Next »
