PC Build
- Re: PC Build
PC Build
14-04-2017 1:13 PM
Choosing the M.2 and the power supply for an office pc to make it as quiet as possible.
We want this pc to last at least 10 years with luck which is what we got out of the old one, but there is one or two things I am unsure on for this board. First is will the memory speed be ok, and second... is the cpu overkill.
I just want get a fast pc that boots quick and will last hopefully.
Stuff....
£ 49.99 Case: Corsair 88R
£ 73.99 Motherboard: Asus B250M-A
£296.48 CPU: Intel I7 7700
£123.98 MEM: 16GB Corsair Vengence LPX 2400
£ 91.99 PSU: Corsair RM650X
£211.99 M.2 Storage: Intel 600p 512GB
£ 84.98 OS: Windows 10 Home Pendrive
Re: PC Build
14-04-2017 1:26 PM
looks a nice choice
Re: PC Build
14-04-2017 1:42 PM
I can have it built with 3 year warranty for another £100 but the board is a B250M-k which has no usb type c
Ponders the riddles... hmmm
Re: PC Build
14-04-2017 2:25 PM
@30FTTC06 - A three year warranty is all well and good but for something that has virtually no moving parts, it's a waste of £100.
Re: PC Build
14-04-2017 3:12 PM
We used to need a lot of RAM memory because if you ran out of RAM then the computer would resort to using the hard disk and that was very slow. But now we have much faster hard drives (like the M2 type), do we still need all that RAM as well? I suspect not.
Re: PC Build
14-04-2017 4:26 PM
I think I was just trying to get a feel of just how fast that pc would be vs my 6th Gen i7 6500U with samsung m.2, mine slugs a little with a VM running @fullscreen with just 8GB Ram, worst case senario I guess - but this sort of gives me an idea of what is likely to happen when it starts getting bogged down a bit with junk if that makes sense, hence the little bit more thought.
Re: PC Build
14-04-2017 7:14 PM
WIth a bit of shopping, the price can come down a bit in total (although some of your individual parts are well priced to begin with) List is at https://uk.pcpartpicker.com/list/dz4ksJ if you want to play with it.
PCPartPicker part list / Price breakdown by merchant
Type | Item | Price |
CPU | Intel Core i7-7700 3.6GHz Quad-Core Processor | £262.74 @ Aria PC |
Motherboard | Asus PRIME B250M-A Micro ATX LGA1151 Motherboard | £70.20 @ Aria PC |
Memory | Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory | £104.99 @ Amazon UK |
Storage | Intel 600p Series 512GB M.2-2280 Solid State Drive | £170.57 @ BT Shop |
Case | Corsair Carbide Series 88R MicroATX Mid Tower Case | £53.80 @ Amazon UK |
Power Supply | Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply | £91.97 @ Amazon UK |
Operating System | Microsoft Windows 10 Home OEM 64-bit | £87.00 @ Aria PC |
Prices include shipping, taxes, rebates, and discounts | ||
Total | £841.27 | |
Generated by PCPartPicker 2017-04-14 19:10 BST+0100 |
Re: PC Build
14-04-2017 7:47 PM
Why would you need 16GB of RAM for a home PC?
I find it difficult to use 2GB and my swap space never gets more than about 20MB - ever.
Re: PC Build
14-04-2017 7:58 PM
Because it is an office PC running Windows 10
Re: PC Build
14-04-2017 8:56 PM - edited 14-04-2017 8:58 PM
Computers have lots of memory but no imagination. ~Author Unknown
Yesterday it worked
Today it is not working
Windows is like that
~Margaret Segall, 1998, honorable mention in the Haiku Error Messages 21st Challenge by Charlie Varon and Jim Rosenau, sponsored by Salon.com
Re: PC Build
14-04-2017 9:07 PM
WoW, those are very good prices, I did look at that site yesterday but was unsure about Aria as Iv'e never used them.
My list was from Scan.co.uk
LN67962 £ 49.99 Case: Corsair 88R
LN77221 £ 73.99 Motherboard Asus B250M-A
LN76876 £296.48 CPU Intel I7 7700
Optional Memory: 2133 LN66140 £123.98
LN69433 £123.98 MEM 16GB Corsair Vengence LPX 2400
LN67193 £ 91.99 PSU Corsair RM650X
LN74684 £211.99 M.2 Storage Intel 600p 512GB
LN66036 £ 84.98 Windows 10 Home Pendrive
In passing this is quite a good deal.. https://www.scan.co.uk/products/3xs-strix-gamer-intel-core-i5-7500-8gb-corsair-ddr4-6gb-asus-gtx-106...
Not sure about the WD 240 SSD green though!
Re: PC Build
14-04-2017 9:25 PM
I've never used Aria either but I like the pcpartpicker site as it allows you to play with things. So you can get carried away on picking the parts and then try to pare it back when you realise your wallet isn't that big.
And it checks component compatibility so no picking a motherboard which your choice of CPU isn't suitable for.
That Scan PC is slightly less well spec'ed than your list although it does have a dedicated video card whereas you have chosen to use the builtin video. So it depends on what work this office PC will be doing.
Re: PC Build
14-04-2017 9:59 PM
The power supply is slightly shy for that build as well, I would pull the big card out and save it for one of the Lads if I did do that.
The pc will be fine at that spec for what we need, I was just going way over the top to get as many years out of it before needing to upgrade, at least 10 years if possible which is what the old pc has done thus far.
So It's bootup time more than brunt vs longevity. If we call it a good 10 minutes before you can touch the old pc at present, that will give a good indication of what we was using
Maybe someone can chip in that has a 750 Evo with the same sort of specs for boot times etc, I know this laptop boots in under 10 seconds ready and waiting and I've used about 200GB so far.
Re: PC Build
15-04-2017 7:28 AM
I have a 850 evo boot time is excellent , also i have a WD black 1 tb when i was looking around reading its said that the Black is better than the green
also the Corsair PSU 750 HXi is very quiet as fan only runs if temp is increased
Re: PC Build
15-04-2017 8:21 AM
@30FTTC06 - This may not help you but for my work I have 4 identical machines each has an Asus H110M-A Motherboard, 8GB of HyperX Fury DDR4, running an Intel i7-6700K 4GHz Processor with Windows 2012 R2 installed on a Type 2240 Transcend 32 GB M.2 SATA III SSD. These machines boot from cold to the login prompt in 5 seconds, and 3 seconds from WoL, and considering the build cost that's very impressive.
I used a small disk as I only needed to install an OS, everything else comes from network shares.
