PC Backup Advice Needed
- PC Backup Advice Needed
18-08-2015 1:31 PM
There are so many on the market that i find it hard to decide which one to choose.
If anyone as had cause to use a backup software and got a good results then that would be helpful as you don't know how good they are until you need it.
Also are any of the free ones that are available worth considering.
Cheers Jack
Re: PC Backup Advice Needed
18-08-2015 2:09 PM
18-08-2015 2:45 PM
18-08-2015 3:07 PM
Thanks for the input guys.
Mook Where is the free unlimited cloud space offer.
Acronis True Image 2016 is £34.99 but to get cloud it goes up to £64.99
http://www.acronis.com/en-gb/personal/online-backup/
Jack
18-08-2015 3:15 PM
18-08-2015 3:16 PM
There is a free version too, but you can trial the paid for version for 30 days(?)!
York.
18-08-2015 4:51 PM
Jack
18-08-2015 4:59 PM
Quote from: NedLudd On another members rec I've just got ToDo Home.
Hi NedLudd,
Thanks for your input.
Can you add more info as i am not understanding what you mean, but then i am a bit thick.
Jack
18-08-2015 5:10 PM
I do daily complete backups of 2 drives to a third external drive. In the event of a problem I can just return the machine to how it was before!
York.
18-08-2015 5:48 PM
Had a browse of ToDo and they seem to get very good reviews even for the free one.
More you learn and harder it gets to choose but i am quite impressed with ToDo
Jack
