Overheating PC
Strat
Fixes: 565
Overheating PC
My PC has been running a little slower of late and occasionally locked up altogether.
On Sunday morning I unplugged everything and took the box onto the kitchen table, opened it up, unplugged and detached the processor heatsink and fan.
Between the fan and heatsink was a good quality Axminster fluff carpet completely preventing airflow from the fan across the heatsink vanes.
Having removed the offending carpet and given the heatsink a good brush and blow I reassembled the unit with a fresh layer of silver heatsink compound.
Now the processor is running 30 degrees cooler and so much happier.
The moral of this story is it may be a pain of a job but it's well worth doing to keep your processor happy. Smiley
16 REPLIES 16
Oldjim
Resting Legend
Fixes: 63
Re: Overheating PC
Alternatively buy a good case with an inlet dust filter or fit one yourself
Strat
Fixes: 565
Re: Overheating PC
That sounds too much like an extraction of money from my wallet, not an easy task.
However it's worthy of consideration when I replace my box Smiley
Thanks Jim.
scootie
Re: Overheating PC
i hover my axeminster bout evey month due to having dogs.
Not once replaced the thermal paste and my runs at same temp still.
i use one of those camera sensor brushes with the air blower on to dust off the fans and heat sink
orbrey
Re: Overheating PC
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=57&subid=795
Fan filters - cheap and effective Smiley (That was the first google link btw, you could probably find cheaper).
I should probably also add, you only really need these on the fans that are blowing in to the PC.
artmo
Aspiring Champion
Re: Overheating PC
Can you tell me how you check the processor speed Strat?
Oldjim
Resting Legend
Fixes: 63
Re: Overheating PC
As I build my computers I always get a case with excellent cooling and then fit a low noise high efficiency CPU cooler.
Just done a check idle CPU core temperatures about 35 deg C full load prime 95 test - see picture
scootie
Re: Overheating PC
thats mine with enough of my dogs fur cloging the fans up at mo to make a woolie jumper
standard dell insprion case with enough holes an slots to post a letter through never mind dust
artmo
Aspiring Champion
Re: Overheating PC
Quote from: Oldjim
Jim, where do you access the core temp screen from?  Also where are you reading the figures you quote?  Thanks.
Oldjim
Resting Legend
Fixes: 63
Re: Overheating PC
Two programs Coretemp (where the picture was from) or Speedfan
http://www.alcpu.com/CoreTemp/
http://www.almico.com/speedfan.php
artmo
Aspiring Champion
Re: Overheating PC
Thanks Jim.  Going out later but will have a look when I get back.  Will they also explain your temp readings?
Oldjim
Resting Legend
Fixes: 63
Re: Overheating PC
Not sure what you mean by explain - they are both monitoring programs only although Speedfan monitors rather more and allows some fiddling with fan speeds and overclocking the CPU.
If you want a more detailed explanation of what is happening just ask the questions and I will try to assist
artmo
Aspiring Champion
Re: Overheating PC
Sorry Jim for not explaining myself.  In your post you said, 'Just done a check idle CPU core temperatures about 35 deg C full load prime 95 test - see picture'
What I'm asking is where are these figures in the chart?  Sorry if it's an obvious question.
Oldjim
Resting Legend
Fixes: 63
Re: Overheating PC
They aren't - here are the idle ones - the screen dump only shows the current temperatures and CPU loading
7up
Fixes: 17
Re: Overheating PC
Quote from: Strat
Lol, glad I'm not the only scrooge around here. I've got into an unhealthy habit of freecycling all of my computer parts.. infact it got so bad I had to re-freecycle 10 P3s that were clogging up the cupboard upstairs.
I'm very tempted though to buy a quiet PSU and quiet CPU fan though.. I think that would be what... the 1st purchase in 3 years? lol
