Outlook wiped profile
- Outlook wiped profile
20-07-2008 8:15 PM
In trying to get the Wife's Treo 500 to work and sync with our outlook calendar, found that the profile was not compatable. So I wiped the profile! Now her old Palm will not sync with Outlook. Is it best to reintall Outlook or set up new profile. Worth noting that we only use Outlook for the Calendar!
1 REPLY 1
Re: Outlook wiped profile
20-07-2008 11:29 PM
Try the simple option first ie a new profile if that doesnt work then reinstall.
If you reinstall then you will need updates for safety.
