Outlook forwarding
the_groundsman
Outlook forwarding
I noticed the other day that when I forward a message the original text disappears.
I have options/preferences/email options set t o include the original message by they are still not there.
wierd this should have only started the other day
Any ideas?
Fixes: 10
Re: Outlook forwarding
You sure its not forwarding the text as an attachment instead?
the_groundsman
Yep - I actuially changed it to that option and changed it back to try and force it to work again but no luck  Cry
Fixes: 10
Hmm.... thats very odd.
Can you PM me your email addy, we'll bounce a few emails to each other to try a few things..
the_groundsman
Sorry missed your post (blame the new forum layout and my age)
It seems that only few EMail addresses are a problem here  (including my work email and another one from someone who has an AOL address ) . With all the rest it seems fine
I'll PM you the address
Thanks for taking the time
the_groundsman
Solved the riddle after hours of trawling the internet  though I Don't understand the technical stuff behind the scenes
It looks like a problem with mail sent as HTML from Lotus notes Email clients only so nothing to do with my end it's the senders Email
