Outlook forwarding
- Re: Outlook forwarding
Outlook forwarding
08-10-2008 10:11 PM
I noticed the other day that when I forward a message the original text disappears.
I have options/preferences/email options set t o include the original message by they are still not there.
wierd this should have only started the other day
Any ideas?
Any ideas?
5 REPLIES 5
08-10-2008 11:02 PM
You sure its not forwarding the text as an attachment instead?
09-10-2008 6:46 AM
Yep - I actuially changed it to that option and changed it back to try and force it to work again but no luck
12-10-2008 12:47 PM
Hmm.... thats very odd.
Can you PM me your email addy, we'll bounce a few emails to each other to try a few things..
20-10-2008 10:20 PM
Sorry missed your post (blame the new forum layout and my age)
It seems that only few EMail addresses are a problem here (including my work email and another one from someone who has an AOL address ) . With all the rest it seems fine
I'll PM you the address
Thanks for taking the time
21-10-2008 9:21 AM
Solved the riddle after hours of trawling the internet though I Don't understand the technical stuff behind the scenes
It looks like a problem with mail sent as HTML from Lotus notes Email clients only so nothing to do with my end it's the senders Email
