Outlook Problem
Fixes: 238
Outlook Problem
Whenever I attempt to run Outlook again I get the following error:
A dialog box is open. Close it and try again.
Outlook has been closed properly after a previous use and no dialogue boxes are open.
Checking Processes in Task Manager shows that OuUTLOOK.EXE is still running. Ending this task resolves the problem till next time I attempt to run it.
I have run the Outlook diagnostic check but no issues were reported.
has anyone else come across this?
Forum Moderator and Customer
Fixes: 62
Re: Outlook Problem
I can't help - never had that problem with Outlook 97 (XP) and 2003 (XP, Vista 64 bit, Windows 7 64 bit)  - but it might help if you advised the version and which version of Windows you are using
Fixes: 238
Re: Outlook Problem
Sorry Oldjim, Outlook 2007 and W7 32 bit.
It's not happening on my 64 bit machine.
Re: Outlook Problem
Quote from: Mav
Yes, occasionally, using Outlook 2003.
I just kill the process as you do. Never found a cause.
I happen to use Process Explorer rather than Task Manager but it's the same result.
Re: Outlook Problem
I have the same setup but not the problem. After googling I found this thread discussing the issue and possible causes, might be worth a read through. http://www.office-outlook.com/outlook-forum/index.php/m/282796/#msg_282796 Good luck.
