Outlook Problem
- Re: Outlook Problem
Outlook Problem
23-05-2010 10:53 PM
Whenever I attempt to run Outlook again I get the following error:
Outlook has been closed properly after a previous use and no dialogue boxes are open.
Checking Processes in Task Manager shows that OuUTLOOK.EXE is still running. Ending this task resolves the problem till next time I attempt to run it.
I have run the Outlook diagnostic check but no issues were reported.
has anyone else come across this?
Quote A dialog box is open. Close it and try again.
Forum Moderator and Customer
4 REPLIES 4
Re: Outlook Problem
23-05-2010 10:58 PM
I can't help - never had that problem with Outlook 97 (XP) and 2003 (XP, Vista 64 bit, Windows 7 64 bit) - but it might help if you advised the version and which version of Windows you are using
Re: Outlook Problem
23-05-2010 11:20 PM
Sorry Oldjim, Outlook 2007 and W7 32 bit.
It's not happening on my 64 bit machine.
Re: Outlook Problem
24-05-2010 9:13 AM
Quote from: Mav Checking Processes in Task Manager shows that OuUTLOOK.EXE is still running. Ending this task resolves the problem till next time I attempt to run it.
Yes, occasionally, using Outlook 2003.
I just kill the process as you do. Never found a cause.
I happen to use Process Explorer rather than Task Manager but it's the same result.
Re: Outlook Problem
24-05-2010 9:40 AM
I have the same setup but not the problem. After googling I found this thread discussing the issue and possible causes, might be worth a read through. http://www.office-outlook.com/outlook-forum/index.php/m/282796/#msg_282796 Good luck.
