Outlook Express problem
penneck
Outlook Express isn't downloading my e-mails (I know they are there because I can get at them on the Plusnet website). When I use the "Send/Receive" button in Outlook Express, I get the following error message:-
The server responded with an error. Account: 'home', Server: 'mail.plus.net', Protocol: POP3, Server Response: '-ERR AVG POP3 Proxy Server: Cannot connect to the mail server!', Port: 110, Secure(SSL): No, Server Error: 0x800CCC90, Error Number: 0x800CCC90
Is there anyone out there who could help me solve this problem, please.
Re: Outlook Express problem
This used to happen to me quite a lot; try rebooting your router (if thats what you're using) it cleared my problem every time.
James
Sorry to hear that you're having difficulties retrieving your email.
Could you possibly trying disabling AVG temporarily to see if this helps to resolve your issue.  Antivirus and Firewall software updates can sometimes cuase these kind of issues.
This is a problem with AVG. A reboot of your PC will probably fix it.
penneck
Thankyou for your help. I've disabled the e-mail scanner in AVG, and now I am able to access my incoming e-mails.
Once again many thanks.
