Outlook 2007 : Confirm open file
- Outlook 2007 : Confirm open file
20-11-2013 6:00 PM
I had a bit of a finger spasm just before I opened a a jpg file I had previously sent myself and accidentally unticked the option to 'Always ask before opening' (not sure of the correct wording).
I have searched how to turn that back on but no luck so far. Does anyone know how it can be turned back on?
Thanks.
Edit: It still works for other filetypes just no longer for jpg as in the shot below.
Thanks.
Forum Moderator and Customer
2 REPLIES 2
Re: Outlook 2007 : Confirm open file
20-11-2013 6:06 PM
20-11-2013 6:16 PM
Thank you Oldjim.
A bit convoluted for W7 but it worked
Now why couldn't MS have made it is simple flag to set within Options?
