Outlook 2003
Spindlewoody
Outlook 2003
I will be out of the UK for a few weeks next year and want to be able to access my emails. Can someone please explain (in plain English!!!!!!!!!!) how I can set up either Plus or MS Outlook to make this happen. Many thanks in advance
Re: Outlook 2003
Your emails are available on webmail.  go to www.plusnet.com and click on the webmail, link.
Gel
Seasoned Pro
Fixes: 14
Re: Outlook 2003
Your e mail prog will be able to receive when connected to an ISP in France, but not
send, without  altering the SMTP settings; you could reply via webmail,
and send bcc to yourself, so they arrive in Outlook.
Fixes: 384
Re: Outlook 2003
Your emails will still download ok in outlook. If you want to send via the plusnet relay you will need to add secure authentication some info here http://community.plus.net/forum/index.php/topic,70383.0.html
As for outlook have a look here http://www.plus.net/support/email/setup/outlook.shtml and in step 5 tick the box that says it requires authentication and add in details as stated in the above post.
My Broadband Ping - PN-Fibre
