Outlook 2003
morgan2476
Outlook 2003
Hi I have just reinstalled windows the only problem i have is that mail is going to unread box and I would like it to go to the inbox - how do i change the settings?
6 REPLIES 6
Re: Outlook 2003
I'm pretty sure there's no such thing as an 'unread box' its simply a shortcut to a filter which shows you just the unread ones in your inbox.
If you go to your inbox, you'll see all the unread ones there along with any read ones too.
pjmarsh
Fixes: 20
Re: Outlook 2003
If you are seeing a link to this in the top left of outlook, this is called your "Favourite Folders".  If you right click on one of them, there will be a remove option, and if you click on another folder not in your Favourite Folders, there's the option to add it to it.
Phil
Strat
Fixes: 565
Re: Outlook 2003
Quote from: James_H
...plus any other boxes you may have created where filtered inbound mail is redirected.
morgan2476
Re: Outlook 2003
The problem is that before all the mail went into the inbox now it doesn't - it all goes into the unread box.
Strat
Fixes: 565
Re: Outlook 2003
Have you resorted your inbox by accident so that the newest email is last on your list and therefore out of sight at the bottom.
Try clicking on the 'Received' column at the top to sort the date latest first and see if they reappear.
HPsauce
Re: Outlook 2003
I suspect the problem is not being described clearly enough so lets try again.
I use Outlook 2003. Unread Mail is NOT an inbox, it's a search folder that personally I don't even display normally.
What is showing in your inbox when there are items showing in Unread Mail?
Is this located in Favorite Folders or All Mail Folders?
