Outlook 2003 help
- Re: Outlook 2003 help
Outlook 2003 help
21-11-2007 4:21 PM
Hi All,
Does anyone out there know the ins & outs of Outlook, my problem is that when I type appointments or birthdays into the calendar & save I get this message: Unable to save free/busy information. Unable to open the free/busy information.This has only started to happen today & I had an appointment timed for 3pm but no reminder came up (no, I didn't miss it!) I can only assume as things are not saving as they should no reminders are issued.
2 REPLIES 2
22-11-2007 7:56 AM
Google is your friend...
http://support.microsoft.com/kb/926084
http://www.eggheadcafe.com/software/aspnet/29378581/how-to-fix-unable-to-sav.aspx
http://www.mcseworld.com/forums/showthread.php?t=9050
Seems to be a common problem!
22-11-2007 2:26 PM
Thanks for your response, all that info seems to be for machines on a server & is a problem that occurs after migrating mailboxes which I haven't got & haven't done.
Anyway, surprise I just entered an appointment as a test & it's all working ok, mystery!!! Thanks anyway.
