Outbound *nix traceroute?
- Re: Outbound *nix traceroute?
09-10-2015 11:05 AM
Anybody got a Unix box on their Plusnet line and able to run an outbound traceroute to somewhere outside of the Plusnet network for me? I'm curious to see how far it gets.
09-10-2015 11:15 AM
iMac:~ Mook$ traceroute postgresql.org
traceroute to postgresql.org (217.196.149.50), 64 hops max, 52 byte packets
1 router (192.168.0.1) 3.584 ms 3.392 ms 5.266 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 55.294 ms 43.929 ms 39.894 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.166) 40.089 ms 40.855 ms 40.825 ms
4 xe-10-1-0.pcl-cr02.plus.net (212.159.0.198) 39.883 ms 43.923 ms 39.996 ms
5 ae1.ptw-cr02.plus.net (195.166.129.2) 40.749 ms 40.209 ms 42.672 ms
6 lonap1.thn.lon.neotelecoms.com (5.57.80.210) 40.391 ms 39.511 ms 41.227 ms
7 ae4.tcr1.rb.par.core.as8218.eu (83.167.63.231) 54.730 ms 48.209 ms 48.453 ms
8 ae9.tcr1.vix.vie.core.as8218.eu (83.167.56.155) 64.943 ms 65.465 ms 65.240 ms
9 xe0-1-1.r06.uni.vie.at.nextlayer.net (212.69.191.150) 64.796 ms 66.376 ms 65.116 ms
10 ae11.r01.prf.vie.at.nextlayer.net (92.60.3.249) 65.988 ms
ae10.r01.prf.vie.at.nextlayer.net (92.60.2.249) 65.755 ms
ae11.r01.prf.vie.at.nextlayer.net (92.60.3.249) 67.649 ms
11 xe-0-0-31.r01.tnz.sbg.at.nextlayer.net (92.60.3.6) 69.725 ms 69.800 ms 69.796 ms
12 213.208.148.110 (213.208.148.110) 70.002 ms 69.589 ms 69.917 ms
13 lo10-c4.infra.conova.net (217.196.145.171) 69.534 ms 71.566 ms 71.110 ms
14 217.196.145.169 (217.196.145.169) 71.597 ms 70.307 ms 70.854 ms
15 zalkon.postgresql.org (217.196.149.50) 69.693 ms 69.849 ms 70.747 ms
09-10-2015 11:29 AM
I get similar results to that domain.
Reason I asked is that I've been scratching my head as to why I've been unable to run traceroutes to certain addresses. Admittedly I only tried a couple of hostnames but they've been timing out at the edge of our network. ICMP traces from a Windows box are fine. Now that I've realised it's not affecting all addresses, it looks like it might just be stuff that we have peering/caching arrangements with:
~$ traceroute bbc.co.uk
traceroute to bbc.co.uk (212.58.244.20), 30 hops max, 60 byte packets
1 192.168.1.254 (192.168.1.254) 7.758 ms 7.433 ms 24.204 ms
2 lo0.11.central11.ptw-bng01.plus.net (195.166.128.171) 23.814 ms 23.558 ms 23.325 ms
3 irb.11.PTW-CR02.plus.net (84.93.249.18) 23.094 ms 22.845 ms irb.11.PTW-CR01.plus.net (84.93.249.17) 22.562 ms
4 * * ae2.ptw-cr01.plus.net (195.166.129.4) 21.809 ms
5 * * *
6 * * *
7 * * *
8 * * *
~$ traceroute google.com
traceroute to google.com (212.56.71.89), 30 hops max, 60 byte packets
1 192.168.1.254 (192.168.1.254) 5.231 ms 4.915 ms 12.184 ms
2 lo0.11.central11.ptw-bng01.plus.net (195.166.128.171) 30.918 ms 30.636 ms 30.398 ms
3 irb.11.PTW-CR02.plus.net (84.93.249.18) 30.154 ms irb.11.PTW-CR01.plus.net (84.93.249.17) 29.699 ms 29.791 ms
4 ae1.pcl-cr01.plus.net (195.166.129.1) 29.186 ms ae2.ptw-cr02.plus.net (195.166.129.5) 29.322 ms 29.094 ms
5 * ae2.pcl-cr02.plus.net (195.166.129.7) 28.627 ms *
6 * * *
7 * * *
8 * * *
9 * * *
I could be wrong, but I'm sure it's not always been like this?
09-10-2015 11:36 AM
iMac:~ Mook$ traceroute bbc.co.uk
traceroute: Warning: bbc.co.uk has multiple addresses; using 212.58.244.20
traceroute to bbc.co.uk (212.58.244.20), 64 hops max, 52 byte packets
1 router (192.168.0.1) 3.555 ms 5.557 ms 5.164 ms
2 lo0-central10.ptw-ag04.plus.net (195.166.128.194) 42.128 ms 40.053 ms 40.352 ms
3 link-a-central10.ptw-gw01.plus.net (212.159.2.156) 40.221 ms 39.984 ms 39.602 ms
4 xe-7-2-0.ptw-cr01.plus.net (212.159.0.252) 40.152 ms 44.132 ms 39.391 ms
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * *^C
iMac:~ Mook$ traceroute google.com
traceroute: Warning: google.com has multiple addresses; using 212.56.71.54
traceroute to google.com (212.56.71.54), 64 hops max, 52 byte packets
1 router (192.168.0.1) 3.599 ms 3.478 ms 4.604 ms
2 lo0-central10.pcl-ag02.plus.net (195.166.128.183) 40.915 ms 41.830 ms 39.912 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.164) 40.412 ms 41.579 ms 40.830 ms
4 xe-10-1-0.pcl-cr01.plus.net (212.159.0.196) 120.928 ms 40.150 ms 40.321 ms
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * *^C
09-10-2015 11:53 AM
09-10-2015 12:11 PM
Quote from: pwatson If it helps, I get the same issue using my Entanet connection - A traceroute from a Raspberry Pi stops as the traffic leaves Telehouse...
Fair enough, perhaps it's always been like this then (although it's only certain destinations it's happening with). ICMP does complete, albeit with non-responsive hops in between.
~$ sudo traceroute -I google.com
traceroute to google.com (212.56.71.218), 30 hops max, 60 byte packets
1 192.168.1.254 (192.168.1.254) 8.096 ms 7.919 ms *
2 * * *
3 * * *
4 * * *
5 * * *
6 * ggc01.plus.net (212.56.71.218) 29.072 ms 28.430 ms
09-10-2015 12:20 PM
traceroute 212.58.244.20 -I
traceroute to 212.58.244.20 (212.58.244.20), 30 hops max, 60 byte packets
1 billion.home.gateway (192.168.5.254) 0.956 ms 0.994 ms 0.806 ms
2 lns12.inx.dsl.enta.net (188.39.1.6) 8.473 ms 8.854 ms 8.323 ms
3 te3-3.inx.dist.dsl.enta.net (188.39.1.5) 8.528 ms 8.298 ms 8.123 ms
4 te2-2.interxion.dsl.enta.net (78.33.141.89) 8.279 ms 8.108 ms 7.937 ms
5 te2-3.interxion.core.enta.net (87.127.236.209) 8.077 ms 8.310 ms 8.465 ms
6 te0-1-1-1.interxion3.core.enta.net (188.39.127.164) 8.707 ms 8.645 ms 8.434 ms
7 te0-0-0-3.telehouse-north.core.enta.net (188.39.127.171) 9.261 ms 9.627 ms 8.802 ms
8 bbc-linx.pr01.rbsov.bbc.co.uk (195.66.236.103) 8.869 ms 8.551 ms 8.306 ms
9 * * *
10 * * *
11 ae0.er01.telhc.bbc.co.uk (132.185.254.109) 8.882 ms 9.252 ms 8.824 ms
12 132.185.255.149 (132.185.255.149) 9.466 ms 8.971 ms 9.086 ms
13 fmt-vip71.telhc.bbc.co.uk (212.58.244.20) 8.511 ms 8.327 ms 9.896 ms
UDP
1 billion.home.gateway (192.168.5.254) 1.368 ms 1.131 ms 0.942 ms
2 lns12.inx.dsl.enta.net (188.39.1.6) 8.287 ms 7.696 ms 8.096 ms
3 te3-3.inx.dist.dsl.enta.net (188.39.1.5) 7.751 ms 7.763 ms 7.834 ms
4 te2-2.interxion.dsl.enta.net (78.33.141.89) 7.871 ms 8.355 ms 8.380 ms
5 te2-3.interxion.core.enta.net (87.127.236.209) 8.354 ms 8.299 ms 8.352 ms
6 te0-1-1-1.interxion3.core.enta.net (188.39.127.164) 8.877 ms 8.923 ms 8.883 ms
7 te0-0-0-3.telehouse-north.core.enta.net (188.39.127.171) 8.940 ms 10.906 ms 10.985 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
09-10-2015 1:19 PM
Try changing gateway?
adw@nofate:~$ traceroute www.google.com
traceroute to www.google.com (64.233.184.104), 30 hops max, 60 byte packets
1 thundertank.avatastic.co.uk (10.0.1.254) 0.584 ms 0.790 ms 0.843 ms
2 195.166.130.210 (195.166.130.210) 13.173 ms 13.617 ms 13.623 ms
3 link2-central10.pcl-gw02.plus.net (84.93.249.162) 14.579 ms 14.593 ms 14.594 ms
4 ae1.ptw-cr01.plus.net (195.166.129.0) 14.571 ms ae1.ptw-cr02.plus.net (195.166.129.2) 14.788 ms ae2.pcl-cr01.plus.net (195.166.129.6) 15.005 ms
5 72.14.223.32 (72.14.223.32) 15.591 ms 15.631 ms 15.574 ms
6 72.14.235.25 (72.14.235.25) 15.590 ms 72.14.223.32 (72.14.223.32) 13.914 ms 72.14.233.39 (72.14.233.39) 14.873 ms
7 72.14.233.39 (72.14.233.39) 14.940 ms 209.85.246.244 (209.85.246.244) 14.376 ms 209.85.246.242 (209.85.246.242) 14.637 ms
8 216.239.41.236 (216.239.41.236) 22.809 ms 209.85.241.1 (209.85.241.1) 23.262 ms 209.85.253.245 (209.85.253.245) 22.780 ms
9 216.239.41.236 (216.239.41.236) 22.690 ms 216.239.42.43 (216.239.42.43) 23.224 ms 216.239.42.37 (216.239.42.37) 23.723 ms
10 * * *
11 * * *
12 wa-in-f104.1e100.net (64.233.184.104) 20.976 ms 20.225 ms 21.688 ms
09-10-2015 2:52 PM
traceroute to google.com (212.56.71.20), 30 hops max, 60 byte packets
1 192.168.1.254 (192.168.1.254) 11.833 ms 11.508 ms 11.267 ms
2 lo0-central10.ptn-ag02.plus.net (195.166.128.191) 30.864 ms 30.633 ms 30.406 ms
3 link-a-central10.ptn-gw01.plus.net (212.159.2.132) 30.180 ms 29.953 ms 29.724 ms
4 xe-1-2-0.ptw-cr01.plus.net (212.159.0.112) 29.496 ms 29.272 ms 28.889 ms
5 ae1.pcl-cr01.plus.net (195.166.129.1) 28.514 ms 28.255 ms 28.016 ms
6 * * *
7 * * *
8 * * *
9 * * *
SWMBO is working from home today, so I'm loathe to do any more hopping
09-10-2015 3:31 PM
traceroute to google.com (212.56.71.29), 30 hops max, 60 byte packets
1 gateway (192.168.0.1) 3.485 ms 3.755 ms 5.225 ms
2 lo0.14.central14.pcl-bng01.plus.net (195.166.130.142) 14.198 ms 16.104 ms 16.454 ms
3 irb.14.pcl-cr01.plus.net (84.93.249.145) 17.756 ms 18.427 ms 19.846 ms
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
Looks normal, some servers will not respond to UDP packets, some servers might not respond except for the ports and protocols used by the services they are running.
# traceroute -T -p 443 google.com
traceroute to google.com (212.56.71.20), 30 hops max, 52 byte packets
1 gateway (192.168.0.1) 2.014 ms 3.672 ms 3.863 ms
2 lo0.14.central14.pcl-bng01.plus.net (195.166.130.142) 12.766 ms 13.414 ms 15.508 ms
3 irb.14.pcl-cr01.plus.net (84.93.249.145) 16.179 ms irb.14.pcl-cr02.plus.net (84.93.249.146) 17.282 ms irb.14.pcl-cr01.plus.net (84.93.249.145) 18.403 ms
4 plusnet-lcy3.plus.net (212.56.71.20) 19.540 ms ae2.pcl-cr01.plus.net (195.166.129.6) 22.650 ms 21.127 ms
A 582n router may also mess with certain types of traceroute.
09-10-2015 3:59 PM
Quote from: ejs Looks normal, some servers will not respond to UDP packets, some servers might not respond except for the ports and protocols used by the services they are running.
Understood. It's just not something I've come across before when diagnosing stuff so it struck me as something that had recently changed. Looks like I'm probably mistaken though so I shall crawl back into my hole
Thanks for testing folks.
