Out of curiosity
Luzern
Seasoned Pro
Out of curiosity
Has anyone experienced Zillya Antivirus? It is mentioned positively in Webuser recently .
What are opinions on this against the other free versions generally recommended?
Fixes: 57
Re: Out of curiosity
This is the old version - I suggest a search here for comments http://www.wilderssecurity.com/forumdisplay.php?f=32
Luzern
Seasoned Pro
Thanks for links Smiley
Looks a bit comme ci comme ca. I'll stay with what I've got. The AV that is as well as the wife Grin
Utterly OT but how does one type accents, cedillas et al on the forum?
pierre_pierre
from another one, you want the ID ten T guide, you have to get the full Font guide, then use Alt plus the position number
