Other
- Other
Other
09-08-2011 12:21 PM
Having looked at my usage for this month and the break down of usage, I see 1% is other
Now, I am at a lost as to what would be other
Any ideas
Dave
Any ideas
Dave
1 REPLY 1
Re: Other
09-08-2011 12:57 PM
Hi DaveMcC,
Our systems can determine the traffic type that is passing through our network and so we can offer a catagory view of your usage. If you have some "Other" usage it just means that the traffic in question simply doesn't fit in to any of the other catagories. At 1% this is normal and as such nothing to be concerned about. For further details you can see our guide here:
http://www.plus.net/support/broadband/usage/vmbu.shtml?supporta=checkusage#breakdownHelp
Hope this helps.
Hope this helps.
