Opinions on my next double build (Second PC added)
- Opinions on my next double build (Second PC added)
- « Previous
- 1
- 2
- Next »
Re: Opinions on my next double build (Second PC added)
20-01-2015 10:34 AM
I also agree with the fast and functional hence the Dell, how good the machine looks will not make it go any faster to me it's the equivalent of a 'go faster stripe' on a car. I use the Dell for mathematical modelling but I also do a bit of this on nVidia GPUs using CUDA so the target is to migrate all possible models to this platform.
20-01-2015 8:52 PM
You don't need a SSD for video editing.
But two disks would be good for video editing.
1TB might be a bit on the small side for video storage.
There are plenty of 2 & 4TB disks out there.
31-01-2015 6:40 PM
On the first box it might be an idea to use Resource Monitor to identify the bottlenecks with your application mix.
Now Zen, but a +Net residue.
- « Previous
- 1
- 2
- Next »
