Opera 9.64 problem with BT Speedtest
paulh
Could other users of Opera 9.64 (Win or Linux)  please try to access http://www.speedtester.bt.com using default site-settings.
If I try to open this site identified as Opera, I just get a blank screen; If I open it identified as Firefox, it seems to work.
Something's changed since I upgraded from 9.27 and I'd like to know if others are experiencing the same before I post it as a problem on the Opera forums
thanks
Paul
7 REPLIES 7
Fixes: 393
Re: Opera 9.64 problem with BT Speedtest
Yep , mine does the same on 9.64 with Ubuntu.
Santiago
Blank screen for me too. 9.64 on XP Sad
Gus
It's not worked on anything but IE for atleast 6 months if not longer
FTTP 500 regrade from Tues 28th November
pierre_pierre
works OK on firefox, with Win XP sp3 and also on Lunux
Results
Test1 comprises of Best Effort Test: -provides background information.
    Your DSL connection rate: 8128 kbps(DOWN-STREAM),  448 kbps(UP-STREAM)
    IP profile for your line is - 7150 kbps
    Actual IP throughput achieved during the test was - 148 kbps
alanf
For me beghaving as paulh described with Opera 9.64 and Windows XP.
Fixes: 393
And that's working ok for a line with a 7150 profile!  Roll_eyes
pierre_pierre
JameseH says  dont rely on the through put speed, its rubbish
