Opening rar files
Opening rar files
Which of the numerous archive managers handles rar files? I have ARK which should but gets me an error. There is a Linux rar file from rar labs site but not sure what to do with it.
Fixes: 21
Re: Opening rar files
I just use Filer-roller, seems to handle almost everything, or try p7zip-full
Waldo
All the archive managers should handle them if you have the unrar package installed.
$ apt-cache show unrar
Description: Unarchiver for .rar files (non-free version)
Unrar can extract files from .rar archives. If you want to create .rar
archives, install package rar.
This package is auto-buildable
Homepage: http://www.rarlabs.com/
Did that Waldo simply worked cheers  Wink
