OpenVPN 1194
RichardB
Seasoned Champion
Fixes: 39
Re: OpenVPN 1194
Hi @Whisper21
When I have setup OpenVPN & wireguard servers, I did not need to use a DMZ.
The Routers port forwarding removed the need for a DMZ.
I would recommend breaking the problem down to find the issue.
Does the VPN server have a static LAN IP address?
Try connecting to the VPN server from a client on the LAN.
If that fails then the problem is not related to the routers port forwarding.
Regards
Richard
machare
Re: OpenVPN 1194
The OP might find it easier to get Wireguard working rather than OpenVPN.
