OpenDNS
Fixes: 9
OpenDNS
Has anyone used or is using OpenDNS ? If so has this improved your internet connection in terms of speed and is it worth doing ?
Fixes: 194
Re: OpenDNS
I am using it, it has solved some intermittent issues that I was having - it's probably best to have one PN and one openDNS in your settings in case there is ever an issue with either one.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 10
Re: OpenDNS
I use Treewalk which doesn't do substitutions when you don't get the name right.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
techguy
Re: OpenDNS
Treewalk is just another version of the DNS client service in Windows which does exactly the same job though granted it might be more efficient.
Personally I think PN need to look at adding more nodes to their DNS resolver service as I think it struggles to cope a little at times.
Re: OpenDNS
techguy
Re: OpenDNS
Very interesting Barry.
Do you not notice occasional slowdowns?
Champnet
Re: OpenDNS
Posted by: adiewoo : it's probably best to have one PN and one openDNS in your settings in case there is ever an issue with either one.
Seconded, but prefer the other way round............... Smiley
Re: OpenDNS
Opendns does other things besides DNS like it warns of any false sites and you can setup a free account and restrict access to sites for kids etc. I use it as one dns and plusnet as the other so I get the best of both worlds this way if one goes down I carry on as normal
