Open Office
- Open Office
Open Office
21-07-2015 2:30 PM
I use a spread sheet on my desktop, using Open Office... it is annoying me, because it keeps foning home to check if there is an update, presumably, every five minutes or so... ( haven`t timed it, ... but it is often....)
It annoys me because it causes corruption in another program I am using at the same time...
Is there any way of cancelling that action, in the settings or somewhere ?
2 REPLIES 2
Re: Open Office
21-07-2015 3:14 PM
Don't have OO, but in LO "Options" has an entry "Online Update" which has a tick-box for automatic checks.
phil
phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Re: Open Office
21-07-2015 3:35 PM
OK.... thanks for the tip...... been there... and yes it does have the same option as you mentioned.... just unticked it... and hope that it won`t keep doing it now.... Thanks
