Open Office update
- Re: Open Office update
Open Office update
26-12-2008 11:31 AM
When first opening Writer, the cursor flashes in the document page as normal, but does not allow input until the blank page has been "clicked in" first...fixed
The mouse wheel scrolling issues (which I've posted about passim) have been fixed.
I would guess that the other applications are fixed for these as well, making a nice suite even better.
26-12-2008 12:42 PM
I've not done much with it yet to check out the new features
http://www.openoffice.org/dev_docs/features/3.0/
26-12-2008 2:40 PM
26-12-2008 10:50 PM
26-12-2008 11:20 PM
And I don't think x.pub files are in the new "semi-open format", like Word and excel.
I use Publisher for a magazine I do - as it is better at some things than plain Word files - and can't afford the better Adobe program.
27-12-2008 6:30 AM
27-12-2008 11:07 AM
Pageplus 9 £9.99
Pageplus 9SE free
27-12-2008 3:02 PM
This is open source.
27-12-2008 4:33 PM
27-12-2008 4:36 PM
27-12-2008 4:38 PM
http://www.scribus.net/?q=release
http://www.scribus.net/?q=faq/vista
27-12-2008 4:49 PM
Remembered my colleague was running it on a Mac (don't know which though) not too sure why though as I always thought (never having been a Mac user!) that Mac handled DTP far better than Windows anyway. DTP is not a huge issue for me these days, I have lots of Publisher files on disks but no software to run them these days (without buying it) Have downloaded the free Serif Page Plus 9 SE, if it seems worthwhile I may upgrade to the £9.99 version, much depends on how well it handles older Publisher files.
27-12-2008 5:11 PM
But yes the publishing / graphic design fraternity seem to much prefer them.
27-12-2008 5:34 PM
27-12-2008 5:36 PM
