Open Office - Main Menu font size too small
shutter
Fixes: 67
I have spent quite some time this afternoon, going through all the settings and configurations that I can think of ( and used before ) to adjust the screen sizes of fonts and other displays.
I have a problem with Open Office, that I have not had in the past 20 odd years of using it !.
Suddenly, the MENU font ( on the top of the page - File   Edit   View   Insert.... etc etc etc ) .  has shrunk to size 8... and the drop down menu`s from there, have also shrunk !...
Can anyone advise me, please, on how to restore the menu text size to a reasonable level, so I do not have to lean forward to within 6 inchs of the screen to be able to read it ! or employ a hand held magnifying glass !.
here is a screen grab to show what it looks like ..
This is a photo...and has been cropped...which tends to make the font size look larger than it is...
Here are a couple of "normal" menu size texts...
11 REPLIES 11
Fixes: 382
Re: Open Office - Main Menu font size too small
@shutter Has there been a recent OO program update?
shutter
Fixes: 67
@jab1   Dunno  ! ... if there was... just seems strange that they ( whowever makes these updates ) would want to change the font size on the menu`s... would not have thought that it was a "worthwhile" thing to spend time doing.
running Open Office 4.1.15... which I think is the latest..
running Linux Mint 22.1
Fixes: 382
Just a thought, @shutter , if that is the only program affected. Can you not check the install date of the current version?
shutter
Fixes: 67
@jab1   done a google on it...
The latest version of Apache OpenOffice is 4.1.15, released on December 22, 2023.
Here's a more detailed breakdown:
  • Version: 4.1.15
  • Release Date: December 22, 2023
as a direct answer to your question... about a month ago...fresh download...
Penny
Fixes: 9
I well remember the days of having to get very close to the screen to be able to read stuff (pre cataract ops back in 2012) so I know how disconcerting that can be.  Hope you get this sorted soon !!
Don't have Open Office here (nor the type of technical set-up that you have) but did go look on line in case there were reports of others experiencing similar issues.
There did seem to be quite a lot, over a number of years - page at https://forum.openoffice.org/en/forum/viewtopic.php?t=47013 - "Font too small in all dialog boxes" - no idea if any of the supposed 'solutions' will help solve your issue, but thought might be worth a try, anyway.
Penny Rollo * * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards * * * * personal website at pennymidasrollo.plus.com
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
Fixes: 382
OK, so it isn't due to a program update then. When did you first notice the font size reduction? The only other thing I can think of is a possible update to Mint, but I don't know - I'm not that technical, and haven't used OO for longer than I can remember - I switched to Libre Office not long after it was released, and as it is the default 'office' program on Zorin anyway, that is what I use.
shutter
Fixes: 67
@Penny  thanks for the linky...unfortunately,..I am not a geek, like the people on that forum. ! !   so I was totally lost trying to figure out what they were on about...  ( worth a try though... thanks Smiley )
@jab1  Yes its the only program that has this problem....at the moment.... so I thought I would remove current version and download a new copy.. ( although it was a new copy just 4 weeks ago ! ) .. and I have done a new install of openoffice 4.1.15
but the font size is still the same.
It`s just a PITA...at the moment...
Thanks for your interest, and input
Smiley
Fixes: 382
@shutter I'm not going to install it on my 'production' machine, I will have need to use my standby W7 one in the near future. If I remember when I fire it up, I'll try OO on it, and see what it looks like on there. Might not be for a couple of weeks, though.
shutter
Fixes: 67
@jab1  OK... Yes, indeedy.... I could do a Windows install on this machine... as I can run windows (.exe ) installs on my Linux Mint... I could also run it on a Virtualbox I have also got on this machine..which has a full version of Window 7 Pro 64bit on it...
For now....I`m taking a rest from it  !... as previously... it`s a PITA !
cheers
TheRoadCrew
Fixes: 13
This, perhaps?
shutter
Fixes: 67
@TheRoadCrew   Thank you ... that has improved the situation somewhat...I did have a look on there, but saw the scale was already at 100% and thought that was the "max"...
I have also found that the max is only 130% but it is a much better and easier size of font to read...
Much appreciate your help..
