Open Office - Calc queries
FIXED- Subscribe to RSS Feed
- Open Office - Calc queries
10-12-2016 9:05 AM
Open Office - calc spreadsheets
I have two spreadsheets that I use, and want to display both on screen at the same time... I have them as an icon on the desktop... If I open spreadsheet A... it opens correctly... but if I go to open spreadsheet B, it REPLACES spreadsheet A on screen. how can I get both copies to be "on screen" at the same time?
2nd query... On one of the spreadsheets, I use the 24 hr clock to record time... however, when I put in a number lower than 1000 it only shows the last three digits...i.e. for 0845 it shows as 845. I have looked at "Format" and some other ways, but cannot figure it out .
Help on both, please.
Fixed! Go to the fix.
Re: Open Office - Calc queries
10-12-2016 9:25 AM - edited 10-12-2016 9:28 AM
Excel has a particular date and time format. In Excel the cell format would be Time HH:MM. I'm sure Open office will copy that.
Edit - which means that 0845 would be 08:45. I'm not sure if you can miss-out the colon.
10-12-2016 9:27 AM - edited 10-12-2016 9:28 AM
Does it not support a Tile or Cascade option under Window or View? And can you use a custom format for the time as HH:MM?
10-12-2016 9:45 AM - edited 10-12-2016 9:54 AM
OK... Cracked the time format.... thanks for the idea guys....08:45 produces 08:45:00 which is a bit too precise... so I tried 08;45 and that shows as 08;45 so semi colon it is...
not sure about the tile or cascade bit... will go and have a look see..
Nope... can`t find any reference to Tile or Cascade.. in View .. window.. or Options.. ...
I have managed to open two sheets... but only through "Open with....... Internet Explorer".. as a "one off" option..i.e. to do the same tomorrow, I will have to "open with..... " again. rather than just click "open" on BOTH items. which is a tad inconvenient. !
10-12-2016 9:58 AM - edited 10-12-2016 9:59 AM
Normally to display seconds you would use SS or maybe ss, so maybe check your format sequence to see if they’re present or use a custom format of just HH:MM
Edit:- Is there an 'Arrange' option pehaps?
10-12-2016 10:19 AM
@Anonymous yes, there is an "arrange" option in the "Format" tool.... however, all the options on the drop down menu are greyed out.. ( on both sheets )...
10-12-2016 10:32 AM
The 'Arrange' was actually in reference to the placement of the open documents, sorry bad context in edit. I don't know what version of software you're running but I suspect there must be a way to view two (or more) open documents at once.
10-12-2016 10:35 AM
Open Office 4.1.1 build 9775 rev 1617669 from the "Help" About drop down.
10-12-2016 10:46 AM
FWIW @shutter I don't actually use OO, but v4.1.3 is available on apache.org. When you open multiple documents do you get any additional menu options appearing; such as Documents, Worksheets, Windows etc? If you do then it might be worth looking at the options they offer, as I find it hard to believe that OO does not support Tile or Cascade.
10-12-2016 10:56 AM - edited 10-12-2016 11:01 AM
I think the use of a colon may cause the programme to treat the cell as a text entry. That superficially solves your problem of removing trailing zeros from number entries but does not give you a proper time format. In the correct format you should be able to manipulate the numbers so, for example, find the difference between two times by subtraction. As @Anonymous says, you had the time format set to HH:MM:SS and you just need to edit that to be HH:MM
@shutter you need to take control and set the cell format yourself, not just modify the entry and have the program guess what type of format you are trying to achieve.
10-12-2016 11:08 AM
I have Libreoffice and this is how I do it.
Open one spreadsheet in Calc.
Click 'Window' > 'New Window' to open a new blank spreadsheet.
Open the other spreadsheet in this new window using either 'Open' or 'Recent Documents'
10-12-2016 12:24 PM
Does on mine.
10-12-2016 1:49 PM
@Anonymous I have the two spreadsheet located on my desktop... as two icons.. ( as if two separate document files ).
as mentioned, If I open one, by right click and "open"... then that is fine... prior to this thread, and my use of I.E as an option, if I tried the same thing on the 2nd spreadsheet, whilst the first one is open, the 1st one disappears to let the 2nd one show. Now that I have opened it with I.E. I get the option on the right click to "open with"... and I.E. is mentioned in the drop down... so it is not really a problem any more..as now I can show both spreadsheets on screen at the same time.
@ReedRichards@... & @HairyMcbiker the time format is not "critical".. and I do understand what you are saying about setting the whole column to show the correct time format... which is where I shall go next !..
@Strat Thanks for that tip... but I think I have solved it now, as mentioned, above.!.
For those who understand... one spreadsheet was my QRZ contact list... the other is a simplified log showing date and time etc... It makes it easier to update them/refer back to them, if they are "on show-on screen" during my qso`s.
10-12-2016 3:00 PM - edited 10-12-2016 3:01 PM
10-12-2016 4:11 PM
This will select the whole column (or row if you click on the LHS ones)
