Ooops
Ooops
I was clumsy and knocked a bottle of Coke (the liquid brown version) on to my keyboard. Arrgh!!
I've given the keyboard 30 seconds under a cool shower head and have shaken the water out. and the board is hanging on the washing line in the warm sun.  Hopefully it will soon be okay, but other suggestions welcomed.
Now Zen, but a +Net residue.
Fixes: 173
Re: Ooops
It won't need ironing but will probably be ok once dried out....and in this weather it shouldn't take long.
Customer and Forum Moderator. Windows 10 Firefox 63.0.3 (64-bit)
Fixes: 21
Re: Ooops
The best option with these is a dishwasher wash  Wink
Failing that new k'boards aren't expensive (unless it is a special one)
VileReynard
All Star
Fixes: 11
Re: Ooops
Coke can be used for general cleaning http://urbanlegends.about.com/library/bl_coca_cola.htm
Re: Ooops
i'd be inclined to do a little more than rinse it under the shower.  it's not difficult to take a keyboard to pieces.  have a  camera handy to image the layout and where all the bits go at each stage of disassembly, then putting it back together is easy.  keyboards tend to be relatively uncomplicated bits of kit.
Re: Ooops
Quote from: Hairy
Last one I bought was well under a fiver.  Shocked
Fixes: 19
Re: Ooops
You could probably dry it out with a hairdryer !...
(Do NOT put it in the microwave !....)
thejudge
Re: Ooops
Quote from: artificer
But it can be a right old PITA to put one back together again. I lost a perfectly functional keyboard because of that annoying bar-clip under the spacebar - the [censored] thing wouldn't gp back right.
Fixes: 341
Re: Ooops
well judging by the lack of response from the OP it sounds worse than he thought Wink Roll eyes
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Re: Ooops
Nope - I've plugged it in this morning after patiently waiting overnight for it to dry. All is well thanks. I particularly like my usual keyboard because it has an in-built mute button and a finger touch volume control.
We always used to trash "coked" keyboards from the trading floors where I used to manage the IT infrastructure. In those cases the traders always swapped their "coked" keyboard from the desk of someone on holiday, by the time the problem was reported the coke had hardened down to sticky caramel.
