On Board Car Diagnostics
- On Board Car Diagnostics
Re: On Board Car Diagnostics
16-11-2007 9:37 PM
Not sure of the postage though as I think you need to register.
Looks like a good site so I have bookmarked it!
Jeff
16-11-2007 10:08 PM
16-11-2007 10:14 PM
Quote from: Pcoventry my god a 500Gb media 3.5inch external for £20!?
Do you need to buy in bulk or can you buy just 1?
It says "hard disk not included"!!
16-11-2007 10:48 PM
Yes you can order 1 of most things....
Postage is dependant on order size and weight. It cost me just over £5 for a parcel of 1kg.
HDD isnt in the price, but how much is a HDD now.
I dont work for them, just have used them and have been happy every time.
16-11-2007 11:08 PM
16-11-2007 11:12 PM
16-11-2007 11:28 PM
Unfortunately some manufacturers make it harder than others to access the fault codes.
17-11-2007 7:21 AM
17-11-2007 8:34 AM
17-11-2007 10:49 AM
So yes, then there's no competition pricewise, buy from China.
Even so, even at Halfords prices (provided you do the work yourself...if any) it's still a hell of a lot cheaper than paying a garage (especially main dealers) to do it. And you only need to buy the tester once. Think how much money you can save your friends and family!!
17-11-2007 11:14 AM
17-11-2007 11:21 AM
http://www.tradestead.com/product_info.php?currency=GBP&products_id=1927
A USB mouse that also doubles up as a slide phone for Skype
for £13 bargain!
17-11-2007 12:07 PM
Quote from: petlew Even so, even at Halfords prices (provided you do the work yourself...if any) it's still a hell of a lot cheaper than paying a garage (especially main dealers) to do it. And you only need to buy the tester once. Think how much money you can save your friends and family!!
All I was looking for was to spend as little as possible to see if it would work - obviously I was pleased with the outcome and surprised at how much good free software was available.
I did buy a double CD for £4 on eBay and that had loads of progs that applied to different vehicle makes but my car was faairly well covered by the freebies.
17-11-2007 12:13 PM
You're on safer ground, if the actual product has a fixed tag (such as those through the material clothing tags) then it's much more difficult for the shop to plead an error.
But with display shelves with slot in price tags, you probably won't get away with it, and anyway bar codes will usually prove a genuine error. But it's probably worth a try though.
The situation is quite different with online prices, as a number of sellers have found out the hard way, too late.
17-11-2007 12:29 PM
Quote from: Pcoventry I like this item.
So do I Pete but if you break down this might be more useful
