Old Netgear DG834 given me but not working
- Old Netgear DG834 given me but not working
- « Previous
- 1
- 2
- Next »
Re: Old Netgear DG834 given me but not working
17-10-2007 3:28 PM
17-10-2007 3:29 PM
17-10-2007 6:11 PM
Thanks for your very patient kindnesses
17-10-2007 9:13 PM
its an excellent router
With one pc just hard wire it which in itself is far more secure plus you have wireless functionality
should you need it in the future
There`s also not much point in being tempted by the later higher data transport routers
unless you are going to be shifting a lot of data over a network this is when they really
come into there own so the netgear will do you just fine
17-10-2007 9:20 PM
Quote from: fcel As for the WAG54G
I have had two of these in the recent past and both suffered wireless failure within 12 months. A quick Google suggested overheating as the culprit and on reflection they did run hot.
Yes there did seem to be many people who had problems with the linksys, i recall at the time that
there were forums chocka with complaints about it so maybe i was just plain lucky but its still running
just fine with no stability or heat problems
17-10-2007 10:00 PM
17-10-2007 11:53 PM
18-10-2007 8:25 AM
Quote from: MikeWhitehead my WAG54GX2 has been running great, with no heat problems
Must have been two out of a Friday night batch I had.
Unfortunately most manufacturers don't fix Bad Batch labels to their products.
18-10-2007 9:04 AM
My initial feelings on that router was that it wasn't particularly intuitive in auto-connecting.
18-10-2007 10:40 PM
19-10-2007 12:24 AM
19-10-2007 6:16 AM
Blimey I never thought am ignorant's question like mine would get all this going.
24-10-2007 4:51 PM
removed
- « Previous
- 1
- 2
- Next »
