Old IE provider still displayed on title bar
- Old IE provider still displayed on title bar
04-09-2008 10:54 PM
Hi, I moved to Plus Net at the start of the year however my IE title bar still reads "Microsoft Internet Explorer provided by X" where X is the name of my former dial-up provider. Is there any way to change this? Any suggestions gratefully received!
2 REPLIES 2
Re: Old IE provider still displayed on title bar
04-09-2008 10:58 PM
Yes. Install another browser, like Firefox or Opera, then delete Internet Explorer from your machine.
Solves lots of other issues at the same time.
04-09-2008 11:02 PM
It won't actually make any difference if you leave it but... If you really want to remove it....
http://windowsxp.mvps.org/ie/ispunbrand.htm
Use at your own risk!
