Oi!... what`s happened to my right hand scroll bar ? ? ? ? ?
- Oi!... what`s happened to my right hand scroll bar...
16-05-2015 2:11 PM
Wassup with it... should I go back to previous version of FF ?
(running Windows Vista Home Premium)...
Re: Oi!... what`s happened to my right hand scroll bar ? ? ? ? ?
16-05-2015 2:51 PM
16-05-2015 2:58 PM
When I pressed Fn and Fn11 key.. they disappeared, until I pressed Fn and Fn11 again...
16-05-2015 4:16 PM
16-05-2015 4:19 PM
As I sed in the opening post.... it works fine from the desktop icon.... like.. now.. I got the scroll bar and the toolbar at the top...
but if I click on a linky they disappear...(from the linky... not the original page )...
16-05-2015 4:56 PM
If it works then it is an issue with one of your addons.
16-05-2015 7:05 PM
16-05-2015 7:27 PM
Strangely... all my addons are available, including Stylish, Ghostrey, Lightshot, Ant video downloader and Xmarks.
My "home page" is nicely coloured, courtesy of Stylish... and so is PlusNet....
16-05-2015 7:43 PM
16-05-2015 8:41 PM
so.. decided that, instead of uninstalling... I would try "erasing".. all refs to Mozilla Firefox. including the maintenance folder... then doing a re-boot... then doing a new install of FF36.01 from my saved downloads.
There is a "menu" bar at the top of this page... BUT... the "address window" is still missing...
totally stumped as to what to do next.... ( I have sent a message back to Mozilla via feedback... but don`t expect I will get an answer ... )...
16-05-2015 9:11 PM
for now.. just have to use Palemoon.....
16-05-2015 11:02 PM
17-05-2015 10:24 AM
Well,... all I can say is that I have, at least got my address panel back.... ( when clicking on secondary linky`s ).. ( As previous )... Still no Scroll Bar on the right hand side... and still no menu bar, ( despite being ticked when right click, as previously mentioned)
Never had any problems with my addons ( as listed ) before... ... ... ... ... ... ... ( all bona fide FF addons )....
17-05-2015 11:40 AM
Quote from: Hairy Try restarting in safe mode (FF not win), you can do so from the help menu.
Did you TRY this?
It would have been the same as removing all the addons/settings and a lot quicker.
My issue was with ABE, but that was pages not rendering properly, just text showing
17-05-2015 11:43 AM
