Office XP
Fixes: 1,483
Re: Office XP
he only wants powerpoint though, not outlook before we confuse things even more Wink
Fixes: 1,483
Re: Office XP
there's also a free web based version of office http://www.howtogeek.com/183299/a-free-microsoft-office-is-office-online-worth-using/
HPsauce
Re: Office XP
Quote from: Petlew
I have Office XP installed on my PC, I have some of its sub-sections running; Word, Excel, but not Power Point or Outlook.
Can you provide more details of it. Such as what the Help About in Word says, what MJB describes it as and what programs and options are in the menu at present for Office.
And was this the same CD you initially installed from?What does the CD say it is - there are various "editions" of Office with different components. You may have a mismatch.
How are you initiating the "upgrade" process? And where did you get the key from that you are using?
HPsauce
Re: Office XP
Quote from: Petlew
I have .............. Word, Excel, but not Power Point or Outlook.
All editions include Powerpoint and Outlook (unlike later versions of Office) see: http://en.wikipedia.org/wiki/Microsoft_Office_XP (scroll down to Editions)
w23
Fixes: 4
Re: Office XP
All editions may have included Word, Excel, Powerpoint and Outlook but a disk of an edition not matching the key will still most likely fail.
Even with the correct edition the retail, volume and academic license disks may refuse to accept each other's keys.
Call me 'w23'
HPsauce
Re: Office XP
Will refuse.  Wink
198kHz
Fixes: 41
Re: Office XP
@ Petlew
Just a thought...
Are you wishing to create Powerpoint docs, or just view them?
If the latter there's a free viewer available from Microsoft.
If the former I'll leave you in the capable hands of HP & Co.  Wink
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
petlew
Re: Office XP
Gentlemen, my thanks, I've just had to rush Mrs P into hospital, I will get around to answering all your comments directly.
HPsauce, I will PM you, you will see why then.
Sorry a bit rushed.
HPsauce
Re: Office XP
Hope all goes well with Mrs P.
