Office Macro's
morgan2476
Office Macro's
Is it safe to set the security level to low in my Office applications?  I have installed hardware and software (Tablet) and every time I started either Outlook or Word I received a bdialogue box asking me either to enable or disable this particular macro.  I thought it would just ask this once but every time I open these programs i get the box.  Any ideas?
Re: Office Macro's
It will be safe the software adds a macro into office for it to work hence why it asks if you want to run it. you only need to worry about macros if they suddenly appear and you dont know were they came from
notheruser
Re: Office Macro's
Isn't the OP's concern though, that setting security level to low will mean that he doesn't know when there are macros in documents?
