Office 2007 Security Update
- Office 2007 Security Update
09-10-2010 5:19 PM
I've just received a notification that there are security updates for Office 2007 (KB982312 and KB981715). The thing is, the only Office product that I have on my PC is Outlook 2003, although KB981715 does mention the .NET framework, which I do have on my PC.
Has anybody else with Office 2003 found the same?
3 REPLIES 3
Re: Office 2007 Security Update
09-10-2010 11:31 PM
If you installed the add-on to Office 2003 that enables it to read files in the new formats introduced with Office 2007 then welcome to the world of Office 2007 updates.
10-10-2010 9:18 AM
I don't think the add-ons are relevant to Outlook, but thanks for the reply. I haven't installed any Office viewers either.
I did install the Time Zone Data Update Tool a few days ago. Since these two updates aren't new updates, this is probably what's caused me to need them.
Thanks again.
Rob
Thanks again.
Rob
24-10-2010 10:17 AM
I've uninstalled the Time Zone Data Update Tool and I'm no longer prompted to install the updates.
