Odd problem
glloyd
Odd problem
Not strictly PlusNet but someone may have found the answer. I run a Vigor 2710n and have several Andoid devices. If I try to make a new connection to facebook via WiFi it fails with the error "Login failure". But if I connect first via 3G first then I can connect via WiFi there after. Can't find anything in the router that would cause this. Any ideas?
