Odd W7 Explorer behaviour
- Odd W7 Explorer behaviour
21-06-2014 1:27 PM
The following happens occasionally and I've never found a cause or simple solution.
Basically creating/renaming a folder, renaming a file or deleting/copying files does not show within explorer until I click the refresh icon or select Refresh from the menu. Sometimes after creating a new folder and doing a refresh I can see the new folder but a different folder is highlighted ready to be edited.
I've tried turning Aero off to no avail. Indexing for all drives is off and I have the latest video drivers installed.
Eventually I reboot as it is irritating as well as a nuisance and, as I said above, I've never found the cause or other solution.
The following links link1 and link 2 offer some insight but each suggests making changes then rebooting but the issue always disappears after a reboot anyway and may not come back for weeks or even months.
Has anyone else come across this?
Forum Moderator and Customer
Re: Odd W7 Explorer behaviour
21-06-2014 8:58 PM
I wonder if MS think we're nostalgic for the days of W98, when a large amount of file moving caused Explorer eventually to hang?
22-06-2014 8:58 AM
This bug is not present initially but manifests after a period of use. It always manifest for me, perhaps associated with my preference for showing extensions for known file types, hidden files and system files by changing the Windows default options?
22-06-2014 10:00 AM
You're on to something there. I use CTRL-E then CTRL-V to move files around. I also have a preference for showing hidden files and file extensions.
The reason I use the keyboard short-cuts is because I then have to rename the folder and prefer to either use keyboard or mouse but not both during the same procedure. I also find using the keyboard a lot quicker. I may try using the mouse to perform the move actions for a while and see what difference it makes.
I have tried a Google search for Cut and Run under W7 54 bit but haven't found much. Do you have any links for further details?
22-06-2014 11:06 AM
26-06-2014 12:06 PM
Windows Explorer can be extremely slow to refresh when the are lots of files.
26-06-2014 2:06 PM
Since the last reboot over 4 days ago it hasn't happened but, then again, it could be weeks or months before it does
26-06-2014 2:14 PM
Next time, use Task Manager (right click on the background of the taskbar at the bottom of the screen and select Start Task Manager) to check what's using the memory - in the Processes tab, click on Memory to sort from max to min (may require 2 clicks).
The problem's usually a browser: close and re-open the browser and it'll probably reduce the memory usage significantly and fix the problem - switch to the Performance tab in Task Manager to see the difference in the Physical Memory Usage History graph.
Have to say, my laptop hardly ever goes more than a month without a reboot as the patch Tuesday updates almost always require a restart
26-06-2014 2:28 PM
I have quit FF when I've had the Explorer issue (usually using End Process Tree as that guarantees all tabs will re-open) but it hasn't changed the behaviour back to how it should be.
26-06-2014 4:57 PM
Could be something else is using a lot of memory, of course. Or maybe even CPU or I/O. When AVG is running a scheduled scan, my machine really struggles until I set priority to basic / minimum.
Try playing with the sorts in Task Manager.
26-06-2014 5:54 PM
