Odd Reverse DNS Hostname
Starmans
I use IRC quite often and on connect the server resolves your IP address hostname and displays it but I received a slightly different hostname to normal.
Host: mail.kyles-on-scotland.co.uk
IP: 81.174.183.53
Didn't know if this is intended or perhaps this IP address shouldn't be in the dynamic pool.
6 REPLIES 6
Oldjim
Fixes: 63
Re: Odd Reverse DNS Hostname
Fixes: 1,474
suspect it's probably an old rdns entry from a static ip. needs removing.
RPMozley
Fixes: 13
That's probably most likely, as with our old static IP it's still on a custom rDNS entry (currently waiting for someone to action the removal).
That's RPM to you!!
Chris
Legend
Fixes: 169
I'm getting it looked into from here.
C1Rider
Is this any help Huh
checking name shows :-
Non-authoritative answer:
Address: 31.216.1.240
checking ip address shows :-
53.183.174.81.in-addr.arpa      name = mail.kyles-on-scotland.co.uk.
Authoritative answers can be found from:
183.174.81.in-addr.arpa nameserver = ns1.force9.net.
183.174.81.in-addr.arpa nameserver = ns2.force9.net.
Cheers..  Wink
avatastic
Looks like that the rDNS on static IPs which have been moved hasn't been updated / reset.
Could be a one off, but given the recent blunder where static IPs had all their rDNS reset to defaults, I'm going to so blunder again.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
