Odd Problem - Failure To Load One Website
- Re: Odd Problem - Failure To Load One Website
18-04-2008 10:09 PM
This is a bit strange.
I've often gone to http://tv.cream.org (80.87.134.99), but over the last few weeks I haven't been able to load it.
I'd assumed there was something wrong with the site, but a colleague managed to get into it on his (work) computer this afternoon. I still can't.
Doing a tracert gives:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\User>tracert tv.cream.org
Tracing route to tv.cream.org [80.87.134.99]
over a maximum of 30 hops:
1 3 ms <1 ms <1 ms www.routerlogin.com [192.168.0.1]
2 29 ms 28 ms 28 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 28 ms 27 ms 28 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 32 ms 26 ms 28 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 28 ms 27 ms 27 ms te2-4.pte-gw2.plus.net [212.159.1.102]
6 28 ms 28 ms 29 ms 195.66.224.185
7 29 ms 28 ms 27 ms te3-3.mpd01.lon01.atlas.cogentco.com [130.117.2.
25]
8 28 ms 49 ms 29 ms Positive_Internet_Company.demarc.cogentco.com [1
30.117.21.106]
9 * * * Request timed out.
10 * (and so on...)
I thought it was my browser settings, but I tried with Firefox and IE6 with the same result.
I also tried my other machine (running Win98SE), but the same happened there with IE6, SeaMonkey and Opera.
This probably means the router is the problem (both machines connect through it and neither machine has a software firewall), but I haven't set the router (a Netgear DG834v3) to block any sites at all. I've upgraded the firmware on it as well, but still no joy.
The router log shows the following when I try to connect to TV Cream:
"Fri, 2008-04-18 22:04:39 - TCP Packet - Source:192.168.0.2,3340 Destination:80.87.134.99,80 - [HTTP rule match]"
The only thing I haven't tried is restoring factory defaults on the router, but I want to know if youse have any other suggestions.
This is the only site I have this problem with.
TIA
25]
30.117.21.106]
10 * (and so on...)
TIA
8 REPLIES 8
18-04-2008 11:24 PM
I wonder if you can get there now I just did a tracert
1 <1 ms <1 ms <1 ms 10.0.0.2
2 40 ms 30 ms 26 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 27 ms 26 ms 26 ms ge0-0-0-303.ptn-gw01.plus.net [84.92.3.9]
4 26 ms 26 ms 25 ms te2-2.thn-gw1.plus.net [212.159.1.54]
5 26 ms 25 ms 25 ms 195.66.226.185
6 26 ms 26 ms 26 ms Positive_Internet_Company.demarc.cogentco.com [1
30.117.21.106]
7 28 ms 26 ms 26 ms ice.cream.org [80.87.134.99]
Trace complete.
and the site comes up for me @ 23:26
Try again and see if its up
30.117.21.106]
Trace complete.
19-04-2008 1:14 PM
Nah, I've had this problem with TV Cream for weeks, when others can access it OK.
It's something at this end, I suspect, but I can't figure out what.
19-04-2008 4:33 PM
Further update:
I find that I can ping & tracert to the range of IP addresses 80.87.134.0 to 80.87.134.9, but not to any above 80.87.134.10.
Could the site/host be blocking my IP address from that range? Anyone with a static IP in the range 212.56.99.n care to try accessing it?
19-04-2008 5:00 PM
It won't load for me
My ip is 212.56.102....
Jeff
Edit: Tracert
1 1 ms 1 ms 1 ms my.router [192.168.1.1]
2 40 ms 43 ms 32 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 34 ms 26 ms 40 ms ge0-0-0-204.ptn-gw02.plus.net [84.92.3.93]
4 95 ms 140 ms 113 ms te2-2.pte-gw2.plus.net [212.159.1.106]
5 25 ms 25 ms 25 ms 195.66.224.185
6 26 ms 24 ms 28 ms te3-3.mpd01.lon01.atlas.cogentco.com [130.117.2.
25]
7 27 ms 25 ms 26 ms Positive_Internet_Company.demarc.cogentco.com [1
30.117.21.106]
8 * * * Request timed out.
9 * ^C
Jeff
Edit: Tracert
25]
30.117.21.106]
9 * ^C
19-04-2008 7:23 PM
Thanks Minkey...looks like we got ourselves a conspiracy!
I'll see if I can contact the webmasters so that they can check with their hosts.
19-04-2008 11:36 PM
try going via a proxy which will hide you ip and see if that works. a list is here
http://www.proxy4free.com/
Check your own host file to make sure there isnt a problem with it
21-04-2008 7:50 PM
Well, I don't know if it was the e-mail I sent to the webmaster on Saturday evening ('cos I've had no reply to it), but I can now get in to TV Cream for the first time in about two months.
Minkey, do you want to give it a try as well to see if they have unblocked that range of IP addresses? Otherwise, it'll be just a pleasing coincidence.
21-04-2008 7:58 PM
Quote from: thejudge Minkey, do you want to give it a try as well to see if they have unblocked that range of IP addresses? Otherwise, it'll be just a pleasing coincidence.
Yep its now working
It must have been your email!
